Throttle Value Problems.
stephen88
My avensis is hard to start, i have changed glow plugs and cleaned out egr valve. It would go to start and then cut out and when i try to start it again it starts no problem. I put a non-return valve on the diesel pipe in case the engine wasn't getting enough fuel, I have put it on the computer and it shows up a throttle valve fault has anybody come across this problem before and how to fix it??
