How Do I Get To Washer Bottle On An 06 Yaris?
KatKat
I need to check the washer bottle on my 06 Yaris as its leaking (well pouring). Not sure if a pipe has come off or if there is a hole but I can't get to it. Tried to take front nearside headlight unit out but can't get that out either. Any suggestions??
remove the roadwheel and remove the wheelarch liner. You should be able to see where the leak is. Could be a displaced washer pump seal.
Regards Geoff Peace.
