Fuel Record
GreyRacer
This is my last five full tank fill ups with V-Power Nitro. I can confirm that in my case at least the OBC is accurate to the arithmetical values. Best has been 42.2 before winter set in with summer tyres but now averaging 39-40 mpg with winter rubber. Mostly Border country roads with a little city and A roads.
David,
do you reset the OBC every time that you fill up? I do, but am advised that it is not the best way to get an accurate result. That said, an accurate 42.4 is not to be sneezed at! My 2008 XT5 has a 11 - 13% ( optimistic! ) inaccuracy between the OBC and the B2B methods. I'm very impressed with the OBC functionality on your motor :thumbsup:
David,
.........which is a function I thought would be pretty standard fayre on my Touch and Go system........wisnae.
