If The Engine Is Replaced, Is The Turbo And Clutch?
Beags
Quick question. My Sr180 engine was replaced under warranty in Oct 2011. I now have 23K on the engine. When they changed the engine, would they have replaced the turbo and clutch. Im assuming so, but not sure..
No they wouldn't... Unless the turbo had some cause to the engine failure! You would have had to paid for a clutch when they dropped the box out! If you didn't pay for it... Then it will still have the same one in there...
