Auris 1.33 Running Cold (Thermostat Faulty?)
Steve Durrant
Hey folks,
My Auris 1.33 seems to be taking a lot longer to warm up than it used to.
About 30 minutes to warm up, heats up quite quick if i leave the heater fan off but when its on it sucks all the heat out of the engine!
I suspect the thermostat is probably faulty?
Has anyone any idea where it is on this engine, any special instructions for replacing it?
Cheers,
Steve.
I doubt the thermostat will be faulty tbh. If it heats up OK without the fan on then I think you are just up against a small engine heating vs you pulling heat out with the fan. I have the 1.33 and reckon on around 3 miles for the gauge to show normal in moving 30 mph traffic. I never have the fan on over "2 bars" on the display.
Thanks for the advice, i'll take the climate control off auto onto no 2 for a while and see how i get on.
