Oil Leak On Turbo
rambler
Just looked under my Rav for those starter leads and seen an oil droplet hanging of the rear engine mount. It is actually coming from above.......its the big hose on the turbo with the big jubilee clip. Its stained a good area of everything below.
Should this joint leak oil still ? , turbo was replaced in may this year.
You will always get some oil in the intake to the turbo because the engine breather from the cam cover is sucked into the intake. Check that the hose is on correctly tho'.
Keith
