Part Id Please Guys
rallying1
What's this part called please?
It's caused my clutch to fail, it's above the clutch slave cylinder, leaking out of the back of it.
Got to order one I am guessing its a Dealer part only ggggrrrrrrrrrrrr!!
6301074D-F2B0-4DED-B498-32DE8BC8E248_zps
Ta folks!!!
Clutch hydraulic damper or clutch hydraulic accumulator - definitely a dealer part On some cars, owners remove these devices in order to sharpen up the clutch action.
So it's not needed, I could just bin it?
The damper is designed to minimise transmission of vibrations etc from the clutch diaphragm and through the hydraulic system to the clutch pedal. I don't know which Rav models have these units and I've never removed one from a Rav. However I've seen a number of cars with these devices removed (Honda, Nissan, LR) and I've yet to hear anyone complain of increased pedal vibration. Removal of the damper eliminates a mushy clutch feel and the bite point becomes more distinct - generally owners see it very much as a positive. For many cars, theres an aftermarket stainless or brass joiner available but it would be easy to use a short length of brake pipe with appropriate fittings to join the two existing hydraulic pipes. In any event, if you don't like the mod - it's easy to reverse - just fit a new damper.
