Hazards Flashing When Eng Switched Off
rob virgo
Since you've had no replies I'll throw this in...
I'm pretty sure the hazards flash if you try to lock using the remote but a door isn't closed, although I've never bothered learning how many flashes means what. Perhaps you're accidentally pressing the lock or unlock button while switching ignition off?
Quick update ,
Still have this issue and it's not me pressing the button when switching off, only happen occasionally but when it does if I stay in the car it's auto locks and if I move then the alarm goes off.
So I must be triggering an auto lock feature or similar ??.
From past experience I could suggest you need a soft reboot of central locking. Somehow the ECU registering the switching off of engine as lock command in which case there will be no error code as it's programmed to do so.
I am not sure how to do the soft reboot of central locking, it's of sequence of opening and closing doors with switching ignition on I guess.
