Avensis 2Ltr D4D
Blodders02
I have a 58 plate avensis 2ltr TR D4D and I am getting an annoying squeaking rattling noise between 1800 - 2200 revs. I have packed out the intake pipe where it enters the airbox and no change. it really is getting me down. the car goes like stink and the MPG is as it should be. I am at the point of getting rid !
I had a similar problem. Whay it turned out to be was a pipe that goes to the air filter box. It was the pipe located on the right side to the outer of the car. It has a foam ring to minimise vibrations, mine simply relocated itself a bit and was vibrating. Could be easily solved in. It took me nearly a month to find and get done. Wish you luck.
