Door Speakers
yarissr
the vibe stuff is quality mate how much you looking to spend?
:D
wonder what wagers that comment
:thumbsup:
depends on the quality, i have kenwood 10cm on dash, kenwood 6*9 on rear , oem at door
thinking of changing to vibe sr69 for rear with blackbox 1 amp
but have no clue wat to do with door ..... as it is pretty thin so not all 6.5" Speakers will fit in there ...
wat do the ice peeps think ?
jaxx - i dont know what you mean hehe!Talking from experience not vibe biased at all!
yarissr - Some may not fit but just depends how handy you are with mdf to make some spacers to bring them out a bit!For sound quality caliber components are very good and also shallow mounting depth,also look at the infinity stuff altough the tweeters can be a bit sharp at times!
as for the rear the vibes can kick rather well,a mate has them and with the bb1 amp they will work well!
any specific models worth recommending ? but dun wanna spend £150+ on them ... as i still gotta get the other equipment too ...
i recommend alpine sxs1757s they are really clear, not alot of bass on em but then thats what a subs for and they dont have to mess about trying to cope with it
also i know somewhere where they are on sale at the mo for £70 as apposed to about £120!
whats the main diffs between co-axels or components, i am looking for sound quality really as the oem sounds kinda sucky....
thanx jaxx - i will chek those out ! :thumbsup:
well if your after SQ then i would suggest components for a start,as for the alpines they are good stuff but the lack of bass might be a problem without a sub,I have found the infinities quite bassy and obviously you guessed it the vibes!lol its what are in my boot!
a coax has another little speaker in the cntre to cope with high frequancys
comps use a separate mid tweeter and crossover
Components have tweeters 2 i think???
Cheers :thumbsup:
no components mean instead of the tweeter being in the middle ofthe speaker its a separate piece which can be mounted elswhere!they nomally come with a crossover to split the highs lows etc to the right one!
due to the depth of the Speakers ....
would i need a special enclosure ? or can i just replace the oems with the new ?
looking at the alpines right now £80 on net and checking the VIBE SA60 gonna check for sum infinity's......
wat have u guys got ?
and btw - thanx for the info ! much appreciated :D
See below 4 wot i've got and it sounds none 2 shabby!
Cheers :thumbsup:
got jbl gtos up front as they were cheap but the trebble is harsh!in the boot i have some vibe components in the rear think they are the sa60 then the rest of the vibe install!
did fitting in the door Speakers impede on the standard door grills ? or can u just take them out ? i am not sure wat the max depth of the speaker i can get ...
well you need to find the mounting depth plus not knowing what your door cards look lik i couldnt comment buddy!
be careful with the depth it took me a couple of attempts to get it spot on as the window normal hits the magnets
:( anyone know wat kind of depth is the max i can get ? the vibes is at 51mm ..... and the alpines are at 61mm
think any of these will fit ?
they will go but your on the absolute limit and have to get it 'packed' out right so it doesnt hit the window
thank you ev3 one for ur help ! :group-cuddles: toc really is :thumbsup:
now i gotta go find the bestest price for these 2 Speakers then c how about to install them !!! :blink:
