Rav4 Key Fob
nsp24
Hi, I have a 2006 XT4 and both of my keys still work but the Plastic has gone on the 2 buttons and I have to push my finger nail in to get them to work.
I have looked on eBay and they all look different to mine with either 4 buttons or 2 on an angle.
Has anyone else found a suitable key/fob to swap the electric's over to replace them.
on the internal electrics it says Denso 12BBY.
Nick.
post-96460-0-74276400-1387494613_thumb.j
This ones a bit cheaper at around £3. You swap over the internal module and blade so you don't need to re-programme. Take care in removing the old immobiliser capsule - it's easily damaged.
http://www.ebay.co.uk/itm/Remote-Key-Fob-Case-Shell-For-Toyota-Camry-Corolla-Prado-Tarago-RAV4-2-Buttons-/390578459318?pt=UK_Car_Accessories_Safety_Security&hash=item5af04a52b6
Thanks for the replies, what's the best way to remove the immobiliser capsule mine looks like its glued in?
I usually cut as close as possible to the chip with a craft knife. Then apply a few drops of cellulose thinners a couple of times and leave overnight. This softens the glue and you can then carefully remove the capsule - no need to clean it thoroughly.
UPDATE, well I have managed to get my new key from eBay removed the chip by melting the plastic with a soldering iron (bit rough I know) just been and had the blank cut this morning it t works perfectly. Total cost a staggering £5.40p so I think I can afford to do the spare key as well :clap:
Thanks again and Merry Christmas :)
