Loud Low Noise
theerroll
Hi all. Looking for some advice...
My avensis sounds as if it is over revving at gear changes. The rev counter however disproves my theory. When I'm coming off the accelerator and down on the clutch i get a low frequency growl a sound I'd expect to hear only much much louder! I have the exhaust checked at my local Halfords autocentre twice this week. They say its fine. They took itnfor a short drive and said it seems fine. I had an oil amd filter change with an engine flush two days ago and its still there. My next thinking isnthe turbo? Any suggestions?? Thanks very much!
when you say a low "growling" sound it makes me think on what was the issue with my car. i had a low growling sound and it almost made me crazy,after checking exhaust and all sorts of stuff i pulled out the airfilter and then i discovered that the plastic pipe from the airfilter Box (in the bottom of the Box) was slightly loose and vibrated. fixed it and the "growling" noise was gone.
could be other Things in With Your car but if i understand Your post correct i would check that pipe,takes 2 minutes to check.
Exactly correct, and there was indeed a TSB fix published for this, probably now out of date, but seek and ye shall find ( don't ask......don't get......)
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
