Turbo
mjw 1701
Recently purchased a second hand apexi acv-r boost controller (old type) ie: oblong 5 inches by about 1 inch bought 6mm and 4mm vacum pipe for solonoid and pressure valve. Pretty sure where the solonoid goes looking at instructions from turbo to wastegate. But where does the pressure valve fit to on said instructions with T piece to the fuel regulator dont know where this is. Can see a vacum pipe on lhs of bulkhead where a turbo timer pipe is fitted not sure though
Any instructions or pictures would be of great help
Managed to do 14.1 secs at santa pod would like to get around 13.5
Have also fitted blitz spec r exhaust plus new 60mm down pipe and induction kit seems quick wont know till ive been to the Pod again after ive fitted boost controller Again any info on fitting i would be very greatful.
