Fuel Starvation
Ali86
Our 08 invincible won't run, it's like it being starved of fuel I've changed the filter
Could it be the pump or could it be dragging air from somewhere any ideas??
Did it happen after changing the filter ?
Does it help if you pump the primer on top of the filter housing ?
Try a tow start
SCV Valve problem? maybe an air pipe loose / fallen off?
Kingo :thumbsup:
  • 4 weeks later...
I'm having a similar problem on my '89 Pickup and I've found the throttle position sensor to be faulty and my mechanic also thinks the fuel pump is at issue (already changed the fuel filter, which was full of garbage unfortunately) as he's had a similar issue on one of his pickups (a Ford) and changing out the fuel pump solved it.
