Hardwiring In-Car Cctv
lacuna83
Happy new to you all!
I currently own a Roadhawk HD in car CCTV system http://shop.roadhawk.co.uk/roadhawk-hd?filter=14 which is powered from the 12v cigarette lighter.
I have now purchased a hard wiring kit from the manufacturer http://shop.roadhawk.co.uk/roadhawk-dc-1-hard-wiring-kit as I would like to camera to run 24/7 from a permanent power supply as the current installation only works when the ignition in ON.
I want to do this as someone decided to scrape the front bumper quite badly, buggered off and didn't leave a note.
If the camera was running then I could have seen who done it and forwarded it to the police.
My question is to ask where the location of the in-cabin fuse board is located (vehicle details below) so that i can wire into a permanent power supply even when the vehicle is off.
My car is a Toyota Auris Touring Sports, 2013 model, 1.6 Manual Petrol.
Thanks in advance :-)
Not sure exactly on that model, but usually if you remove the drivers side kick panel in the footwell you can access a fuse box in there on most models
Kingo :thumbsup:
Again this may not be of any help.. but my 2007 right hand drive UK auris... fuse board behind glovebox which needs removing to access.
