Help,
stevieg43
Im new to this forum and im seeking help, tonight on the way home from work my N/S front light bulb blew low beam, and since this happened I have the red Battery light on and water in fuel warning light on and also the water in the oil light on too. the alternator also makes a nasty whirring noise has done since I purchased it 2 years ago.
regards
steve
Replace the bulb and have the alternator checked, also check for any water ingress due to the extreme weather conditions.
alternator --- > check condition of connections / degrease them; have multi tester and measure charging voltage;
oil level ---> be sure you have no an oil drinking issue;
water in fuel filter ----> time to time you should drain fuel sludge from filter housing -- it is normal.
PS, Welcome to the club... Enjoy :driving:
had this on an Auris yesterday at work. Was a broken wire coming off the alternator and corrosion on a connector. Once that was fixed all lights went off
Alex
Welcome to Toyota Owners Club.
Moved to Avensis club
