6 By 9s
breezer
if its less than 177dB then no
where can I get it from?
whats the RMS on it?
from the states i would expect, there were limited ones built but you may be lucky if you can source one. i think the one in the picture is for sale for about $4200
you need a Maddas Uranium Charged Power Supply to run it tho, available from the east somewhere, can never find them tho...
and a specially built custom amp
also a transit van to provide the enclosure
RMS is approx 3700watt
WTF I can get an 15" AudioBahn 10000W RMS 20000W Peak
Ill check again, and scan the image from the booklet
well its not the best idea!
6x9s dont even need an enclosure and will more than likely dampen the bass effect and you cant get proper L/R stereo positional accuracy!
in fact a stoopid idea!
what wrong with 6 x 9s in a box? is that a stupid idea?
Cheers
Matt
the whole point in 6x9s is because of the size of the parcel shelf and how to use this to an advantage a box is pointless as they dont have enough room behind!Best bet is a cheap sub and some good components up front but some Speakers somewhere up back for some rear fill!
