Fuel Pump Temperature Sensor
rambler
Hi folks.
I've had a personal conversation on here with a very kind helpful member,thank you.
Can anyone tell / show me where this is please , upload a photo / pdf etc etc.
Is it part of / within the the fuel filter area ?
Is it easy to access / replace? , I cleaned my own MAF sensor last year.....very very easy,just wondering if this is just as simple.
Hi Rambler,
If it is a picture of the fuel temp sensor you are talking about all you need to take off in the engine bay is the top engine cover and the two ten mm nuts holding the expansion coolant contianer and the fuel temp sensor can be accessed with ease sitting on top of the high pressure pump.
Doug.
