Interior Light
lehto
which one do you mean the centre roof one or the ones above the dash
The second generation Auris went on sale in December 2012. Have you got the first generation or the second generation Auris?
On my previous Auris there was a small recess at the rear edge of the lens. Careful levering with a small flat screwdriver, possibly using some soft cloth for protection, should dislodge the lens and give access to the festoon bulb
I pushed the surround up and pulled the lens down at the same time
Small holes between the lens and plastic. Put screwdriver (thin one) in and tilt. DO NOT try to remove the whole unit, or you will end up with broken holders!!!
Slightly different but does anyone have a secret for the 2013 Auris's boot light cover? I pry and pry and the sod just will not budge; any more force and I'm sure I'll break it
