Baffle plate weeping oil, I am baffled as not many mechanics have heard of this part yet alone fix it, toyota have quoted me over £500 also quoted me nearly £800 for clutch problem high biting point, please can someone HELP!!!
Is this related to an Aygo, as according to your profile you have a Yaris?
Have found the following topics - the first including a fix:
http://www.toyotaownersclub.com/forums/topic/121646-aygo-2007-baffle-plate-oil-leak/
http://www.toyotaownersclub.com/forums/topic/121012-aygo-engine-oil-leak/
Would have thought any mechanic having access to a copy of the first post could do it.
Presume the Aygo is a manual - if so I'd shop about for a replacement fitted clutch. Of course it would be cheaper if the two jobs were done at the same time.
Thanx very much for your help me & mum will have a look now thanx again
If you have a new clutch fitted, make sure you get the larger 190mm clutch (as opposed to the original 180mm clutch).
