Hello
Paulbee
Hello ,I am Paul and own a1994 rav4.
The fuel guage isn't active at all. there seems to be no power reaching the fuel indicator there is no low fuel indicator light... checked fuses ..they are fine. I have checked the fuel tank sensor connectors at the rear under the seat. they look good, no corrosion.I am thinking that there may be a loose connection behind the console..Im not sure whether I should attempt to remove panel. don't want to do that really. . ..Stuck at the mo.. so any advice to check something I haven't would be very welcome. I will continue researching :) cheers!
Paul
Hello Paul - welcome to Toyota Owners Club.
