ive just upgraded the Speakers in my aygo go 2011 which had 2 tweeters in the windscreen pillars and 2 Speakers in the passanger and driver door, i want to add 2 more Speakers in the back but im not sure how to install them so any step by step guides or explanations would be great
Have a look at the following:
links removed as OP said not helpful
this is not very helpful i really just need to know how to connect the Speakers to the head unit
Your original question was "i want to add 2 more Speakers in the back but im not sure how to install them so any step by step guides or explanations would be great"
Not that 'you only wanted to know how to connect the Speakers to the head unit.'
Your original question was "i want to add 2 more speakers in the back but im not sure how to install them so any step by step guides or explanations would be great"
Not that 'you only wanted to know how to connect the speakers to the head unit.'
I would say connecting to the head unit is a major part of the installation
also would i need an amplifier or new head unit to do this?, if so then what types are best for a low price
I was just wondering how could add 2 new Speakers to my aygo (I have two tweeters in the windscreen pillar and 2 Speakers in the front doors), I want to add two new Speakers to the parcel shelf and need to know how to connect the two new speakers to the head unit and whether or not I need a new head unit or an amplifier and if so which ones?
Don't you have a pair of speaker on the dash board upper surface (one on each side)? Just having tweeter on the A- pillar and a pair on the door does not sound right.
The newer Aygo have tweeters on the dash board upper surface and a pair of Speakers on the front door. Is that what you have got? In that case your head units rear channel needs to be activated before you can connect another pair (rear pair) of Speakers.
Try here: http://www.toyota-tech.eu/aimuploads/%7B8E0B2D26-BAD0-95B1-EAC7-219A32E4BAD0%7D/Audio%20Soundpack%20speakers%20tweeters%20RHD%20AIM%20322-1%20PZ422-99240-60.pdf
No you do not need a new head unit or amplifier to install extra Speakers, however the sound quality & feature count can be improved by doing so, as standard you will have tweeters in both front A-pillars, 10cm shallow fit Speakers under the grilles in the top edge of the dash board and 16cm shallow fit Speakers in the front lower door panels upgrading the dash & door speakers can make a big difference.
The newer Aygo have tweeters on the dash board upper surface and a pair of speakers on the front door. Is that what you have got? In that case your head units rear channel needs to be activated before you can connect another pair (rear pair) of speakers.
yes im sorry if my description was off, i have a tweeter in each pillar and a speaker in each door, how could i activate it and would the original head unit suffice?
The link given shows how and where to wire additional Speakers and if you are happy with the head unit yes it will suffice
The link given shows how and where to wire additional speakers and if you are happy with the head unit yes it will suffice
sorry didnt see the ling before i posted, thanks for all your help!
