Oil Change Light
trevor254
How do i knock off the oil change light on my 07 hilux as this is not scheduled for another 5000 miles
thanks
Turn the key on. Observe the odometer. Is "ODO" displayed? If not, push the trip meter button until "ODO" is displayed, with the total mileage travelled shown.
Turn the key off.
Push & HOLD the trip reset button until advised to release it.
Turn the key to "ON" (do not start engine)
Observe the ODO display.
You should see 5 dashes, then 4, then 3, then 2, then one, and finally, five zeros.
The original mileage that you observed should be redisplayed.
Release the trip reset button.
The proceedure is now complete.
thanks for the reply...unfortunately its not working any more suggestions
Rastlins procedure is correct but try this
Set odometer and two trip meters to trip meter A with the engine switch ON,and turn it to the lock position.
Turn engine switch to ON position while pushing trip meter reset knob.
Do not start the engine,but keep pressing the reset knob.
Release the reset knob more than one second after the trip meter displays 000000.
The system should now be reset.
