12" Neons At The Front
cokg2
Hiya
I want to get two 12 inch neons for the front. Just wondering where i would wire them into.
Basically, i want a permanent connection, with a switch which i could turn them on/off when required. Not fussed about them coming on when the doors are open.
Im a little "unconfident" about wiring, so guidance would be very greatful.
Cheers :thumbsup:
where, and how could this be used to control a neon install?
sorry if its a stupid question
tap the power of the cig lighter cables, that what I think Ive done, or I might have done it from the radio cables
hope this helps , and is not boring.take a 12 volt+ from cigerette lighter supply.
to your choosen switch. then a wire from your switch ,feed a coil of a relay (12volt)
+. the 12volt - for the other side of coil take to body work (metal) .this will allow the relay to go on and
off from your choosen switch . a12volt +supply from your Battery to a inline fuse of a rating of 5 amp should be sufficent.from the other side of fuse holder take awire to your neons,this willbe 12volt+. from your car body work,take a wire to the negative side of your neon. please note this is only one option of many. there may be a simpler way that other people have knowedge of .
