İnjection Indicator Lights And Gear Does Not Up 3-Rd Vites
simsono
Hi everyone.
İ have problem with my RAV4 2010.
Some days ago, it's injection indicator lights, gas pedal don't response and gear don't go up from 3-rd gear.
I have gone to a lot of service. But they could not diagnose what is problem. Some said, change gas pedal I changed it completely. Some said wash liquid system. I did it. But problem has not solved.
Please, if anyone has any opinion about it, please write.
Thanks a lot.
Just to check my understanding...........Is the car petrol and with automatic transmission? What do you mean by injection indicator lights? Are you saying that when you press the gas pedal - the road speed doesn't increase and the gearbox doesn't change up from 3rd gear?
hello. yes it is petrol and auto transmission.
indicator light is engine light.
yes. when I press gas pedal there is not responding from engine in parking case.
when drive gearbox does not change up from 3 gear.
You need to get the car checked for fault codes. If you don't have access to an OBD code reader - any garage can do this for you. If you let us know the codes - we can help you further.
