Water In Drivers Footwell And In The Boot
hi there fellow carina owners
i have a 1995 carina cdx auto saloon, which i love to bits but ive got a couple of little probs,
1) ive got water in the drivers side footwell, checked sunroof channels but no joy and plenum chamber is clear so not sure.
2) the left hand corner of the boot is wet too, not sure how its getting in.
any help in this matter would be gladly appreciated thanks
thanks for quick reply, i did notice under where the spare is today it was wet, at least i kno where to check. its just the front thats the pain now, it got soaked again, apparently ive heard the door rubbers can fail???
have solved the wet boot problem, still getting water in the front, any ideas would be much appreciated thanks???
Have you got a blockage in the air vent under the windscreen (leaves)...
If you have a sunroof, check the drainage channels aren't blocked.
Pollen filter - if you have one (usually accessed via the glovebox) might need replacing.
Also if you have air con, have a look forward of the passenger footwell for the air con evaporator pipe in case that is blocked.
thanks for replies, yep had the vent off and it seemed clear, but havent checked sunroof channels, will take a look, i believe it does have a pollen filter so will check that too, it dont have aircon. will get back to you asap
:cheers:
ok have checked sunroof channels, all clear, so it looks like its the pollen filter or the windscreen are the 2 likely suspects, thanks for replies, will check these out
found it, leaky windscreen!!!, thanks for replies every1. :D
