How To Remove A Roll 'n Lock Cover ?
Magwych
My 2011 Hilux Double Ca came with a roll 'n lock cover for the cargo area. Handy for most times, but when I to use the cargo area to its full capacity I want to temporarily remove the cover.
According to the brochures removal is a simple 10 minute task. Apparently it is so simple that there i no informaton available regarding how to do it...
For thsoe in the knw is it as simpe as removing the screws through theside plates, the ones that go into the flat metal tongues. That frees off the side plates that the cover slides through. It seems to me that these plates are the only things that are positively holding the main cover asembly in place, is that right?
Once the plates are removed the main cover assembly should just lift out. Re-assembly, in the time honoured Haynes tradition is reversal of disassembly.
Anything I have missed?
