3.0 1994 Kzn130
mark kzn130
hi, does any one know what the steel plate which sits behind the pedals on my 3.0 kzn130 hilux surf is called? it stops the firewall from flexing when you put the clutch pedal to the floor. mines snapped and I need to buy one but cant find what its called! cheers guys
Remove the plate have it welded and bolt it back in, you will save time and money if you have not already fixed the problem
