Rav4 Lambda Sensors
johntom
Hi I have a 2001 rav4 2.0 vvti, are the 2 top, pre cat lambda sensors the same?
obviously the plugs are different but are the actual sensors the same ie part numbers 89467-42020 (left) and 89467-42010(right)?
Both Lambdas do the same duty so the head design will be the same. For banked Lambdas, part numbers are different simply because of different length leads or different connectors. (connectors are nearly always different to prevent the sensors being cross wired accidentally - OBD wouldn't pick this up)
