Yaris Lower Engine Cover Panel
sceh
Anyone got a photo of the locations of the mounting points for this? I assume I can remove just one side and don't have to remove the whole thing? I can only locate one bolt so either they are well hidden or I am stupid. I need to do this to remove the engine mount to remove the fanbelt. When I am finished I will write to Toyota and ask why their engineering team don't talk to the maintenance people...
I assume you mean the cover under the engine compartment.
There are two bolts on either side in the wheel arch.. jack up the driver's side, remove wheel and they are mounted vertically above the vertical part of the cover which runs from front to rear of the car - hidden by the wheel which is why you can't find them....
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
