55 Plate Rav4 D4D Problems
Pfc1969
Can I firstly say that I love my rav. However a few problems are occurring.
The one that is griping me occurs after the engine has warmed up and the temp needle is half way. If I then turn the engine off, the engine dumps the Battery power on turnover as in a flat Battery. I know this is now not the case as I have a brand new Battery in it.
The engine, once cooled starts after turning over normally.
Can ANYONE help? What's up wi me Rav? How do I fix it?
Hello Pete welcome to Toyota Owners Club.
Topic moved to Rav4 club - should get a better response.
This sort of issue has been reported on a couple of occasions recently. As well as the earth connections - check the security of the positive feed where it connects to the starter motor. What spec Battery have you fitted (the CCA value on the Battery is the important parameter) - some batteries listed for the Rav diesel are inadequate. Further tests are required but a defective starter motor is a possibility.
