Can Believe Im Asking This
pedro7680
Generation 5 pop up.
my head light has blown,.
how the heck do i swap the bulb?
is it easy??
i saw my neighbour do his once , he practically takes out the whole unit .tell me ur vin number , i can send you a sketch of light unit . how its put together .mpickles666@aol.com
B) I changed mine by first removing the black plastic shroud(4 screws).Then taking off the headlamp cover(4 big screws on sides).The bulb is then accessable.A bit fiddly but can be changed. :thumbsup:
Yep, its easy to do, as said above :thumbsup:
Also, remember to leave ur light switch on the "service" (first notch) setting.
The amount of people who have run up and told me: "ha ha! ur headlights are broke- they're stuck up!"
And the amount of times i've answered "I've only stopped here a minute and left them like that" :blink:
Sometimes i take the key out when they're half way down to get the "sleepy celica" effect- must confuse some people that :lol:
As back cat said.. it can be a pain if they aint been changed for a while and they are nicely stuck in place!.. lol
while your at it you might as well do both sides, and upgrade bulbs,, I put in superbright xeon bulb from Halfords,,, Made such a difference. There about 12 squids each :thumbsup:
yeah and they blind us poor lowered guys lol :P
Didn't some of the Gen5's come with sealed beam headlamp units???
The early models did but I have a 94 model and that does't have sealed beams .. But with some cash missing out of your pocket you can replace them... Also today I changed the rear brake light bulb,, If like me you doing it for the first time,,, You need to take the vented bit of the rear lense off. ( put a very small screwdriver between the lense and the vented bit and prise very carefully. underneath are two screws, remove them then take the little small square cover off " which you need the boot open" and there is a screw under there, remove this and the light unit will come away from the car...) I broke my vented bit finding this out...
got it done lads and lassies
after a lot of hassle
i popped the top cover off and just fought the bulb out.
piece of cake
