Gear Box Problem
TIM125
Hello i have got a Toyota Avensis on a w plate done 135k mile been a good car.iTs a 2ltr automatic.
The gear box or clutch has just starting to slip.A little knock when going into reverse or drive its ok after 2min of driving then after 5 min it slips bad after 10 min almost will not move.I spoke to one garage who
told me to scrap it and another who said it may be a filter in gear box which would need changing.just wondered if any one has any advise many thanks Tim
Hi Tim and a big welcome to the club.
There has been many posts on gear changing probs that have been caused by a malfunction in the ECU.
If you search for a company called ECU Testing in Derbyshire it may be worth giving them a bell.
There have been glowing report of this place from members on the RAV4 forum so maybe a search on there under "harsh gear changes" will help
If you do ring ECUT get the number on your ECU as they will be able to tell you if they can help.
On the rav section there are warnings that inaction can wreck the transmission.
There is a discount from there for club members if you cite the code DON.
Hope this is of help to you.Come back if I can help you more
Del
Firstly have you checked the fluid level in the gearbox? Assuming you have then the best bet is to get it to an auto specialist. They will usually do a few tests, for a reasonable fee, and let you know the best course of action. I dont know what type of box it is but assuming it to be a conventional auto it could be the fluid flywheel has lost its oil, although this will mean removing the gearbox to replace it it will be cheaper than having to replace the gearbox. If it needs a new box then it may mean it is cheaper to scrap it. Most garages won't have the skill or equipment for testing, they will just send it to a specialist and add their fee, hence best to straight to the ones that know.
