Mod Chips Add Hp To Motor
GT4 BOOSTER
only 3 wires and hey it works , more VROOM VROOM , best £ 10 i spent,want 1 ?
Is this like the +20 bhp mods on eBay by any chance?? If so then you have wasted about £9.50 Its a 50p resister from Maplins.
we all have opinions yours goes noted - but i found it did make a difference.
have you put it on a dyno, no graph no power increase, you can easily imagine a power increase using seat of your pants dyno :(
just bear in mind your autochoke is now jammed open and youll suffer damage in future to the engine!
my rev counter is still the same at tick over -auto choke is controlled by hot water entering throttle body , and im using less fuel ,and my pants dyno knows when things are faster ty. :yes:
No I'm not saying it doesn't work, IT DOES, but only under certain cicumstances apparently. What I'm saying is that if it is the eBay thing you could have done it much cheaper. The eBay mod is basically a rip off money wise. All you need is a resister (8100 ohm 0.5 watts) that you can buy from places like maplins for about 50p.
:yes: yes its from eBay , its sealed in a grey plastic box ,i got more improvement with this than i did from a 90 quid k and n induction kit , some men like black chicks some dont end of story :yes:
if i;d known this before hand i'd of bought the resistor ,and used it,but hey we all live and learn ,some buy heroine , i bought a 50p resistor .
'This modification is NOT suggested to do if you have knock !Removed! or detonation. When you are in an environment where the intake air temperature is below 57 °F this modification will not benefit your cars performance. These conditions will hurt performance instead of improving it. ' Sounds a bit scary to me, beware the ides of march! so if its below 12oC you gonna kill your car in winter!
who wants speed in winter the weather is ***** poor anyways ???? u just take it off .
