Ok... I get my oil and filter changed every 3000miles or there about at Mr Toyota.
Apart from that no servicing, unless something needs sorted out.
What else should I have looked at ? Any other fluids in the car should get changed etc ?
any info greatfully appreciated.
whats your mileage mate? at 90000 the coolant needs replacing
44,000 miles...
so nothing else needs done then ? Sweet..... :)
there is no harm in doing that earlier mate... :thumbsup:
at 45000 youre due for your first coolant change mate!!
i was assuming you had more than that and thats why i said 90000! (second coolant change)
ah... coolant change... ok
ta... lol
hth :P :D
Coolant - every year or two .. you to keep it fresh.
Brake pads - replace when needed.
Plugs & leads - get them off and have a look.
I only fix stuff if it brakes or wears out .. been working okay on my last 3 cars ..
