2003 Yaris 1.4 D4D Timing Chain Replacement Guide
tomtom1084
Hi I have a 2003 yaris 1.4 d4d and its done 103000 miles so I need to change the timing chain. I am a fairly competent mechanic but does anyone have a guide on the timing marks and what is involved as I have never done a timing chain on a Toyota before. Thanks Tom
oh yeh forgot to say I need to replace my water pump (its leaking badly) as well does anyone know how easy/hard it is to replace? Any info would be much appreciated. Thanks Tom
What is wrong with the chain, Toyota regard it as a whole life item and don't have a replacement schedule.
The info you require can be purchased from here: http://www.toyota-tech.eu/
access can be bought by the hour, day, week etc
hi, its just noisey and the water pump is leaking so I was going to change both at the same time. Is it a big job to change cam chain and water pump. do I need any special tools to lock the cams or fuel pump? Thanks Tom
