Cruising Distance Yaris
Nick Brown
How is the cruising distance worked out?
Screen shows 270miles remaining so put 2 gallons in and it still shows 270 miles.
Is it dependent upon the amount of fuel you put in.
At a guess, I'd say driving style over the last few miles but I'm sure a more knowledgeable person will be along shortly.
IIRC it only resets when you fill the tank up? (Or was that just the mpg??) :unsure:
TBH it's best taken with a pinch of salt anyway...
Think you need to put at least 15 litres in for the range to adjust properly
As what frosty said from empty you need about 12-15l in then drive then car and it will re adjust, any less and it will stay stuck
Alex
Thanks all will keep you posted .
Must say this car is miles better than the aygo.
Further to my last post.
Filled up and all works well, it seems that you do need to put more than a tenner in at each fill up.
Updates on car absolutely no problems.
Good to know
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
