Avensis Vibration At 3000 Revs
tpagr8
My 2003 Avensis 1.8 T2 has developed a vibration when under load, specifically when around 3000 revs there is a vibration/resonating that can be heard and felt through the pedals. All tyres have been balanced, wheel bearings checked, the drive shafts are also ok. No vibration when in neutral. Are there any other potential areas to check? I don't thnk it is gearbox related as it only occurs at 3000 revs and above that it disappears. Only thing I can think of is engine mounts?
