Blown Stereo Fuse
Grezer1974
Can any one help please?
I pressed the cig lighter and my stereo and mpg screen went off Cant find an internal fuse box with blade fuses inside
2004 corrolla t2
Hi, Welcome to the club... Enjoy :driving:
Instructions
1/ Look under the steering wheel, to the left of the bonnet release lever. The interior fuse box panel is square with a plastic lip used for a handle. Pull on the plastic lip to open the fuse box.
2/ Release the bonnet lock by pulling on the bonnet release latch under the steering wheel.
3/ Lift up the bonnet then locate the Battery.
4/ Follow the Battery lead cable toward the vehicle passenger compartment. The lead cable will run toward the fuse box. The fuse box--depending on the year of your Corolla--will have a metal or black plastic cover. Newer model Corolla fuse boxes are labelled, and will have a fuse reference diagram. Pull the cover off to access the fuses.
