Engine Swap Problem
toyocel409
I AM SWAPING A 95 7AFE INTO A 3SGTE. I GOT IT IN THE ENGINE BAY BUT NOW THE CROSS MEMBER THAT HOLDS THE MOTOR MOUNTS FOR THE ALLTRAC TRANNY AND THE FRONT MOUNT IS NOT ALAING RIGHT WITH THE LOWER PART OF THE CORE SUPPORT. DOES ANY KNOW IF I CAN USE A CROSS MEMBER FROM A 3SGE MOTOR.
THANX :help:
How are you converting the ALLTRAC transmission to 2 wheel drive?? Most people who do this swap use the tranny from an MR2 Turbo, a much neater option I would have thought. You may have to source a X member from an ALLTRAC.
