Proper Strange!
asnelling
Hey guys. So last night I left my lights on and flattened the Battery, jumped it to get it home and charged the Battery. Now whenever I sit in the car it shows the "door open" light and the hazard lights flash for about 20 seconds, it stops for a minute or so the repeats. How do I stop this? Thanks
Are you using the remote key fob to unlock the car? Your car sounds as though you have a faulty alarm, many people stop using the remotes due to a fault and everything will be ok until the Battery goes flat, then the alarm resets and in your case is trying to sound when you open the car it seems that at least the siren is faulty but the hazards are flashing which is the alarm going off, to stop it you will need to use the unlock button on the remote key. Then to bypass the alarm once unlocked just use the key in the door to lock / unlock from then on
