Stereo Fuse Location - T25
Bilb
It looks like I may of blown a fuse for the stereo power from the looks of it.
Basically I was adding a smartlink system to my stereo when I managed to touch the ground directly to the stereo's casing. This sparked a little and power was then lost with nothing working.
I have checked the fuse on the stereo itself which is fine, so my first thought is that I have buggered the stereo and was taking it out to send it back.
However, as a last check I put the original TNS310 back in however this is also not getting any power to it, so I now think it is likely a fuse within the car. The only problem is I'm cannot seem to find the stereo fuse.
Does anyone know which fuse box it is on and where?
On the drivers side, near the steering wheel, Open the flap pull it out fuses sit behind it and there are also fuses behind the glove box
Yeah, I guessed it would likely be in one of the two fuse boxes inside the cabin, just wondered if anyone know the actual fuse for the stereo?
