Nct Or Mot Failure
Gervin
hi guys,just had my nct or mot y day,and my 01 avensis has failed on imbalance on parking brake+ABS,and the reason i got was, its not workin(ABS) i mean,would anyone know would it be a simple diy fix,like a new sensor?any help would be appreciated,thanks gerard
There was a recall:
TOYOTA announced a problem with the AVENSIS affecting a total of 1,537 vehicles.
The brake pipes leading into the ABS actuator may have been incorrectly positioned. This could cause an imbalance in performance under heavy braking.
Vehicles built from 01/2003 to 03/2003 are at risk.
The following remedial action is necessary to address this problem. Check and reposition the brake pipes if necessary.
thanks for the reply,and the info,have 28 days to fix the prob so will have a look t morrow,thanks again
