Lambda Sensor
bev21
hi there my avensis has just failed mot on emmisions, was told to use cat cleaner, which this has made it worse, so now fitted a lambda sensor will this do the job
How bad were your fail results ?
Sometimes driving like you stole it can help.
I assume the car is serviced and doesnt have any other issues?
same happened with my car, i used (lucas upper cylinder lubricant and injector cleaner) just pour into your fuel tank b4 the mot, i used it and my emissions were dramatically reduced, it will get u through the mot then u can concentrate on the issues causing it.......
