Lambda Sensor Wireing
petebrit
the lambda sensor on my celica has been cut and the plug has been removed. can any body tell me the connection order of the different colours of the wireing so that i can slave in another plug? ( there are four different colours) 1994 jap import. ;)
the sensor is on a multi plug , match them up to that ??????
If you buy a generic sensor rather than one from Toyota the wires are often different colours.
The site I got my 4 wire sensor from had a wiring diagram, you could look on there to see if it is any help. Try http://www.justlambda.co.uk/
