Windscreen "crackle" On 2013 Avensis Tourer
David Hulse
I've got an annoying "crackle" on the front windscreen of my 2013 Toyota Avensis Tourer D4D. The noise is only there when the car is moving and varies with the temperature. On a warm day there is little or no noise but on a cold day it is much worse. Has anyone else experienced this problem and more importantly have they found a cure for it?
It sounds like the seal has gone, pop in to a windscreen replacement store and they will check it for you, probably free of charge...
Has it had a replacement screen?
Sometimes these glass repair companies don't glue them in correctly.
No it is the original screen. I have had the car since new last September. Thanks anyway
Then would go to Mr T and get him to fix it under warranty
