Toyota Warranty, White Dust
pandor83
Hi Guys,
So white dust is blowing out of the vents when i switch on the air con. I called up toyota to arrange a check but was told that i'd have to pay £50 for the air con diagnostics, even though it's still under warranty i'd still have to pay even if there were a problem.
Is this normal?
thanks
Have a look at this fairly lengthy topic from the Auris club:- http://www.toyotaownersclub.com/forums/topic/150197-white-powder-coming-from-air-vents/
Is this similar to the dust you're getting?
Particularly note posts 24 and 48.
Might be as well to take a print out of relevant posts from this topic with you to the dealer.
Presumably you have an extended warranty or Approved Used warranty - as your car is outside the 3 year/60,000 mile new car warranty.
