Fs: 2004 Corolla Tsport
Sam.
The interior of the car is very tidy, no broken pieces of trim or scratches/gouges.
Its been well modified in the right areas, it drives very well, makes all the right noises when pressing on but is quiet and civilised for daily duties, Returning good MPG (So I think anyway).
It has fairly extensive service history pretty much every receipt for everything ever bought for it, in a well kept folder.
Previous owner fitted a new clutch and the Celica gearbox.
Since I have had it I've done the following;
Stripped and cleaned the Inlet/Throttle Body/Idle Control Valve/MAF
Engine Oil Change (Millers XSS 10W-40) Added a Magnetic Sump Plug
Gearbox OIl Change (Castrol Syntrans 75W-90)
Coolant Flush
New Spark Plugs (NGK Platinum Plugs)
New Brakes Front Refurbished Callipers/Pads/Discs, Rear Pads/Discs/Shoes, Fresh 5.1 Fluid
4 New Pirelli PZero Nero Tyres & Laser Alignment
Replaced numerous pieces of trim/Fixings
New Osram Night Breakers (Replacing the crap HID's)
New Lift Bolts and Rocker Cover Gasket
Cleaned both the VVT filter and VVTL filter
New Accessory Belt Tensioner and Belt
Brass Shifter Bushes
Recent Machine Polish
Re-wired the amp in the boot
Modifications
TTE Sports Lower Springs (Supplied and fitted by Toyota)
Fidanza Lightweight Flywheel
K&N Typhoon Induction Kit
Goodridge Braided Hoses
Whiteline ARB's
Decent Audio Install Vibe Components/Alpine Amp/Sub etc
Celica Gearbox (Better 6th Gear for cruising supposedly)
Team Heko Window Deflectors
Important Bits
12 Months MOT (No Advisories)
Tax till May
103k Miles
2x Keys and the Grey Master Key
Alsace Granite (Grey)
The heaters blow hot and the AC Ice cold
Standard Bits
TTE Body Kit
Automatic Wipers
Climate Control
Electric Window/Mirrors
Automatic Dimming Rear View Mirror
Bad Bits (Every Car has them)
Headlights have a bit of clouding, Will polish out though.
Small scuff on the rear bumper
Few car park dings
Small split in the drivers floor mat
Cigarette burn on the base of the drivers seat (Never bothered me too much as you cant see it when sat in the car)
Photos
Price
£3000 ono
I think this is a fair price considering the condition of the car, all the recent work carried out and the modifications it has, I am open to offers but they need to be realistic.
The car is located in Bristol, Test Drives are welcomed but Proof of Insurance or a large deposit is required.
