Any Known Problems
garry auris d4d
hi guys I am new to the auris range and have just got 2.0 d4d on 57 plate is there any known problems with this model I was going get the sr 180 model but was told they have headgasket problems just wondered if d4d 2.0 had any know faults ?
the 2.0 D4D Auris can also suffer from excess oil consumption, head gasket failure etc. production dates "Auris with 1AD or 2AD (Prod. Date: Sep 2006 to Sep 2009)" albeit they don't seem to have the same failure rate as the 2.2s.
Toyota have an extended warranty program in place for the issue though for up to 112,000 miles or 7 years.
Thanks Raistlin parkers guide helpful so upgrade wheel nuts and claybar and polish with paint sealer to start with
thanks Heidfirst i was dreeding this thought it was just sr models thats why bought the 2.0 d4d model is there any way to reduce the problem or cure for good eg stronger headgasket or better oil ect
leaks from the rear cluster but easy sorted
rear cluster is that the light cluster your speaking of if so how do you put right is there a post on cureing the problem
it's supposedly due to carbon build up so don't use cheap fuels, don't trickle around at 1200rpm, give it a good blast every so often etc. etc.
thanks Heidfirst well mate I use asda total and Shell fuel but mix them so not using same all time and well to be fair not often I sit at low revs unless stuck in traffic also use recommended oils when I find out what they are only problem other than this may be if fit chip box but waiting on results from here want use blue spark from eBay but waiting see if it will but lot extra stress on car mine only got 49k been driven by old couple so first give it a blast then find out if worth cleaning or changing egr valve if it has one not sure about diesel engines in Toyotas want use good products but have be safe with pennies for bit until get used to running costs
