Couple Pics Of Mods To Do
garry auris d4d
just thought put couple pics of wheels and coilovers I would like to fit any info or feedback welcome the wheels are secondhand and near me £200 and the coilovers are just under £700 from demon tweeks plus this what car looks like from side and this is the chip box I would like to use £80 from eBay
post-139120-0-30535700-1395147421_thumb.
post-139120-0-32025400-1395147449_thumb.
well cross off cr tech blue spark chip box been told stay away as may not be good for engine so back to searching for better box
The wheels look smart Garry - but have you checked how much they weigh ? Some aftermarket rims are stupidly heavy and you will notice the difference. Lots of extra unsprung weight is never a good thing. I'm not familiar with that name, so can't really give an opinion on them. Are those KW coilovers ? If so, they normally start at around £1100 ! Have a look at BC Racing coilovers too, as they normally retail around £600 with the added benefit of adjustable damping - not just ride height. I've had them on other cars, so feel confident in their product.
thanks Uncle Buck yea bcs are good had them on my evo most can ajust camber to as for wheels not sure about weight but for 200 with tyres even if tyres nearly done seems like a good buy but unsure I know there 5x114 et45 with 215 45 16 tyres yes there just 16" but that's whats on car now one thing not sure about is center bore think mine is 60 but unsure without taking wheel off and checking also looking at these wheels now there new and local to me
post-139120-0-08019200-1395179683_thumb.
have to order blue spark pro at a cost of 199.99 at moment but this doesn't have boost control plus theres two different ones not sure which mine is theres a 126/300 and a 126/310 how do you tell the difference ?would like to order one with boost control but cant seem to find one for my model on blue spark site
Your best bet is to ask somewhere that can run your plate to tell you I'm going to Toyota to ask them they should know ... What spec engine also 200 for wheels and tyres is a good price but also what tyres are you looking at for that price
Sent from my HTC One SV using Toyota OC mobile app
Those coilovers on the pic are KW cannot get them for that price. If you're going to lower the car don't go for 16" wheels, they will be too small. Go for 17" size or if the rims have lip like the ones on that pic you can even go for 18". They should also be at least 8" wide and ET 40 or less. With ET45 they will be too much inside the arches, just like stock wheels.
If you're planning to stick with 16" you need 205/55 size for tyres. Center bore is 60,1 I think but you can change that with adapters no problem.
Speed_Chaser thanks sorry for misleading price yes I checked and it is for different model I put price up so sorry for that. cheapest I could find was £960 for kws but in my search I found bcs br edition at larkspeed for £684 this I confirmed to be sure so this is price for them on 20/3/14.
Yeah sounds right, you should test them. I am looking at a set of those myself too! Cheaper than KW but should be of a good quality.
used to have bcs on my evo there are good quality for that car so should be same for ours and price seems ok if they do same as evo ones as camber and height stiffness can all be changed
